so i took the carb apart and it looked clean all accept the bottom of the bow and the bolt/drain that holds the bowl on. i sprayed it out, i didn't take it all apart because i haven't seen a rebuild kit for it, it's a mikuni carb.
this much i do know, it runs with gas the the carb, or ether, and at this point the pump actually pushes gas into the car because it was full when i took it off.
does anyone have more info on this cart? and does anyone have pictures of how the oil injection is supposed to be blocked off? because i'm pretty sure it isn't blocked off, but the reservoir is gone along with the lines.
thanks again- hearsrider
