Start with a compression test. The 2 strokers run in both directions and will wear faster in the forward rotation. Do the compression test with the throttle wide opened.
It's time for a rebuild. 100 lbs is about the minimum compression the 2 strokes will run decent on. The compression should be at least 120 lbs on a healthy EZGO 2 cycle engine.
