EZGO 1990
dlord
I have a 1990 EZGO 2 stroke that hasn't been run for 2 years. Installed a new battery and it turns over but no fire.
removed the carb and cleaned it also removed the fuel pump disassembled it and found one of the clear diaphrams was falling apart. My question is can I add an electric fuel pump rather than use the original if I replace the original and block the intake and outlet fittings? The other is can I just mix the oil with the gas without causing problems? Iam not sure if the oil pump is working, Is there a way to check it to see if it is working? Thanks
