Have an EZ go gas about an 04 or 05, wont go in any gear, took off belt and when I move the driven clutch the cart moves slightly both in forward and reverse but wont move under power
the splines are known to strip out in the brake drums on the ez go's. you can check this without removing the brake drum, check to see if the nut that holds the brake drum on spins when you push on the gas.
