EZ-GO not so EZ---GO
chazell
I was just givin a 82 EZ-GO cart. I'm trying to get it running. I put new batteries in it, have the diagram and rewired it the correct way, however when I press on the accelerator i don't go, I do get the buzzer in reverse just no movement. Any ideas? Thanks for the help in advance.
chazell
Yes the silenoid clicks when i press the pedal. Are the coils behind the motor suppose to get hot or not.
If your talking about the resistor coils, yes they will get hot when running the cart slower then full speed.
chazell
I get no volts to the coils when the accel is pressed in. If that helps i'm also getting 33 volts to the S2 all the time and 33 volts to the S1 when accel is pressed. When not pressed I'm getting .01 volts to the S1. Does this help?
