ez-go gxt840
what could be the problem...the belt from the starter will turn but the clutch/pulley
is not grabing the belt that turns the rearend
no its turning over good but it usually grabs and fires on up....i had a problem with it floodin out .after i cleaned and adjusted my carb it would run like a champ while the it was on stands but i would go to test drive and make it about 50yrds.ending up pushin back to my shop .idk
The engine has to start be fore the clutches will engage. You need to figure out why it's not starting. I'd start with adjusting the valves if you haven't already.
divot61
also check the vacuum tube that goes to the fuel pump, blow back into the vacuum tube, there might b some oil in the tube, wont pulse the pump if its full of oil
