My cart will go forward but not in reverse...this just started. The F@R switch looks OK. Pls tell me how to check the micro switches mounted on thr F@R switch...I have multimeter
What year is the cart? To check the micro switch set your meter to ohms. It should read 0 until you push the arm and give you a reading when you activate it.
