ez-go electric
builderbob
I rewired my ez-go TXT with a heavier gauge wiring so I had the batteries out and have checked and re checked my wiring and have found it to be correct. However I now have power for forward and reverse but I haven't any headlights, horn, the dash battery indicator does not show battery condition until I depress the gas pedal. I have checked my fuses and they are ok, I have checked each battery with a volt meter and they all read ok.
I have a wire loom in front of the batt. with a black to the neg. post, white to the pos post, and small red to the forward, reverse controller. In the back of the batt. I have another wire loom with a black wire going to the neg side of the batt. and a red to the pos. side.
(I think this area might be my problem) Any Ideas? Thank you Bob
divot61
yes pics are worth a thousand, and dog, ur avatar green machine is sick!! i love it!! got more picks of it?
builderbob
In order to try and clarify as much as possible let me start with the purchase date of 11/29/2000 and serial no of E100 1270888 ad it is a TXT model. The photos show a red wire hooked to the pos side of the bat. And black to the minis side is from a wire loom going around the back of the batt’s and under the cart to the ignition. ( I suspect). The wire loom to the charging receptacle is comprised of white to Pos on the batt. Black to neg on the batt. And a small red to F-R controller. I have not disturbed any small wires on the controller, solenoid, or the F-R switch. In order to dbl. check my main wiring, looking down at the back of the F-R switch A is on top and going clockwise B would be on the passengers side, C on the bottom and D on the Drivers side. It is wired as follows, A to M-, B to S-2, C to A2, D to s-1. The controller is wired, B+ to A-1, B- to the neg. batt. And A2 to A2 and Batt pos to the solenoid. You guys are amazing, thank you Bob
PS.cant figure out how to add photos.
