EZ go 99' txt dead
amishman007
Hello,
Trying to fix my fathers EZ go electric golf cart. Turn on the key and put
it in reverse and no buzzer. The solenoid clicks once when you push the pedal
but does not keep clicking when you keep repetively push the pedal. I tried
to bypass the reed switch with no luck. Batteries are charged. Any suggestions?
Welcome to the forum.
It could be a bad connection. Check ALL the cables and make sure they're clean and tight.
Is this a series cart (does it have a run tow switch on the controller cover)?
What is the total battery pack voltage?
amishman007
Yes, it has a run/ tow switch.
I have not done an exact voltage test but all batteries have
been individually checked and each are over 6.0
From what you descibe it sounds like a bad cable or cable connection so check that first. There's a troubleshooting guide in the EZGO Resource forum that has some tests in it. It should help you to figure out what the problem is.
shadowman
also try jumping the soleniod, a clicking soleniod dosn,t mean its good.............................
