ez-go 90
TV23
I have an ez-go 90 4 stroke that is hard to start. Eccecive cranking,cleaned carb,have spark,also cleaned&inspected fuel pump... Did compression test and results were slowly climbing to 150psi. Need some input please
shadowman
did E-Z go make a 4 stroke in 90? i thought it was 92? try taking some carb cleaner and spraying the crank seals while cranking over.......if it starts you know seal or seals are going bad..............not uncommon on E-Z gos...........................................
