FireFighter
I have an 89 Ez Go that you have to flutter the pedal before it will kick the motor in. I have noticed that sometimes it helps to wiggle the shift lever (the F&R board is new) and other times it seems to help if you pull the choke out. I am not real famiiliar with golf carts, and was just wondering if it could be a switch gone bad or something? Also sometimes the motor turns over but it doesn't fire. This always happens when the motor is warm. Any suggestions would be much appreciated. Thanks Dean
