engine won't run I'M REALLY STRUGGLING
blazerblobs
I bought this cart in pieces. It's a builder. It's a carryall-1. 1995. The first cart I have ever owned. Any way When I first brought it home it had no spark, Easy enough, I put a new coil on it and now there is spark. However the engine will only run at a fast idle now, and when I try to rev it up it rev slightly and then slows down. Like it is running out of fuel. I've tried everything, new fuel pump, new fuel lines, I am starting to think it is something else. Do these things have governors? Do they have to be in gear to rev up?
Any info is helpful.
Thanks,
Jim
Yes, there is a governor on it. However, I'd suggest pulling the carburetor and cleaning it out REALLY well. Put new, fresh gasoline from a brand-name store in it, and try. Also, for the fast idle, put more throttle cable into the black governor/solenoid box. Try that and see how it is.
shadowman
and remember you can put the cart in maintence mode..........yellow knob undr the seat square in the middle there.............pull knob out and turn about 50% and put itback in thanput cart in nealtral so you don,t have to jack the rear end up.........if theres one thing i like about C.C. its the maintence mode..................................
