I'm looking to upgrade my 87 CC. I saw the Kawasaki 16 hp for $1500, and the FE 290. Is there a motor in between them that will bolt into my CC, if so, can you tell me where to buy it. [email protected]
Neither will bolt right in. The mounting plate will need upgraded along with the air box and the control box will interfere with the hose to the air box. I did it to my 89. Later I switched frames to a 94. But it can be done.
Thats ok. It can be done and it was easy to do. I first started by just drilling out the mounting plate for the engine. Later had grooves milled for engine alignment. I had a spare air box and I cut the old style contol box lid to make room for the hose. I did have to fab up an accelerator cable to the carb.
