Engine Stops Running on EZGO TXT Gas Golf Cart
RC3CART
The engine stops running on my 2015 EZGO TXT gas golf cart after about 5-10 minutes of riding. It dies comes to a stop and starts right back up. Any ideas what my be going on with it?
RC3CART
Mostly just riding around the yard or trails. May be a stupid question but how would oil level affect this? Thanks for your response.
When the engine stops running you need to check to see if it's getting spark and gas to the carburetor. If you try starting it right away after the engine dies does it just crank on the starter or do nothing? Over full of oil isn't a good thing. Welcome to the forum. :hattip:
RC3CART
When it dies the starter continues to turn. I can let off the throttle then press it and it starts back up immediately
Patrick L
Can you jumper that switch just too see if its still a momentarily defective switch ?
When the engine quits, does it die immediately or does it stumble or seem to take a couple seconds ? Immediately would make me think about electrons and stumbling a bit first would lead me to fuel.
