Engine Runs-on
bendall
I have a 1990 G2AF that the engine just keeps running (very slowly) after I take my foot off the gas pedal. Only way to stop the engine is to turn the key off. When I turn the key on, the engine starts running again until I turn the key off and then it stops. What do I need to adjust to correct this problem?
Zman
Sounds like control circuit is keeping solenoid energized when gas pedal released. check stop switch on gas pedal to see if it is stuck or if wiring is shorted. If you need a wiring diagram go to the resource section.
