Charged each battery - up to 1/4 to 1/2 full and, individually, and am getting 5.85 - 6.0v for each of the 6 batteries. Pack voltage was up around 35v. Water level is good. Hooked all the batteries up again and started to charge - but as it was charging, I noticed:
1.) When charging, the resistor coils where getting warmer
2.) Ignition key off but cart was in reverse - after charging for 1 hr - the reverse buzzer went off.
3.) Moved the Forward/Reverse switch to neutral and got a spark.
So, guessing the batteries are ok. Based upon the new symptoms:
- I'll pull apart the F/R switch assembly and visually inspect - HOW CAN I TEST THE ASSEMBLY TO SEE IF IT IS SHORTING? Just a simple continuity test or is there something else ? The microswitch is clicking and apperas to be ok.
Also, starting to wonder if my controller is bad and/or shorting out ? I'll pull it apart to and visually inspect thia too - HOW CAN I TEST IT ?
Once again, I appreciate all of the suggestions and help !!!
