mikeisclutch
I have a 2007 yamaha Golf Cart. I use it about 1-2 times a month. However last time I used it, the turn signal was left on and drained the battery. Upon discovering the drained battery I charged it. Now the problem is no power to the starter. I have headlights, taillights, turn signal, horn, brake lights etc... however no starter when the accelerator pedal is pushed. I removed the plastic guard on the "starter's solenoid" I believe, and am able to jump across the (+) and (-) with a jumper wire. When arcing across the wire, the starter cranks over like normal, however the accelerator pedal is not doing anything. Is there a switch, or fuse that might be blown between the pedal and the starter, or are there any other trouble shooting ideas any of you might have for me. Thank You.
