Electrical Problem With Battery Charger
bailes
I'M HAVING AN ELECTRICAL PROBLEM WITH MY BATTERY CHARGER. IT WILL NOT ON WHEN PLUGGED IN... I HAVE BEEN REDOING MY CART AND AM STARTING TO PUT IT BACK TOGETHER...I HAVE AN 2001 EZGO TXT 36 V...I DISCONNECTED ALL THE CABLES AND CHECKED VOLTAGE ON EACH BATTERY AND I HAVE 6 VOLT READING ON EACH ONE...I,M NOT SURE IF I HAVE SOMETHING HOOKED UP WRONR OR NOT..I HAVE ALMOST 36 VOLTS AT THE MOTOR...DO I NEED TO CHARGE EACH BATTERY SEPERATLY OR WHAT?
bailes
HERE'S WHAT I HAVE...VOLTAGE AT CHARGER...(FEMALE END) IS 36.4 VOLTS I HAVE 36 VOLTS ON THE 2 OUTSIDE LUGS OF THE CONTROLLER...36 VOLTS ON THE OUTSIDE LEGS OF THE SELINOID...AT THE CHARGER RECEPTICAL THERE IS A LITTLE BLACK DOIDE? OR SOMETHING THAT RUNS TO MY R/F SWITCH...I ONLY HAVE 2 VOLTS AT THE R/F SWITCH...WHEN I TURN ON THR KEY I HAVE NOTHING...NO BEEPING WHEN IN REVERSE...NOTHING...I GET 2 VOLTS AT THE BLUE WIRE ON THE OFF/ON SWITCH...IS THERE SOMETHING I'M MISSING, DID I BLOW A FUSE OR SOMETHING? I'M LOST CAN ANYONE HELP?
