Electrical issue
Pat912
Hello all,
Im not sure Im in the right thread here so please redirect me if needed.
I recently purchased a custom cart from a dealer in my home town. It was built on an EZ-GO platform but i think they pretty much gutted it. The receipt says its a 2005 PDS. Ive been able to find out that i have an Advanced D.C. Motors Inc. 36 Volt motor and 2005 Trojan T-605 batteries. It also has a speed chip but Im unsure of the manufacturer. I am new to carting so please bear with me. If anymore info is needed to diagnose my problem please let me know what and how to/where to obtain it. So here goes....
I have recently noticed quite a reduction in run time and general battery power since the purchase of my cart (May 09). When i hit the accelerator my battery gauge(analog) dips all the way to the "E" side, my radio cuts out, and then regains its power. This is on a full night charge. It used to not make it 1/4 of the way down from "F". My acceleration has been severely hindered but it seems to make it up to top speed if i give it some time. I thought i may be low on water so i checked the levels. The front 3 were fine while the back 3 need a little. I added distilled water to the batteries and charged them overnight. This did not solve the problem. I have tried disconnecting all loads from the batteries (CD player, speakers, etc.) with the same results. Any input would be greatly appreciated.
-Pat
dougmcp
Check your battery connections for corrosion. Clean and tight is your friend.
If that is not the problem, your batteries may be on the way out.
After a full charge and rest at least an hour after charging, get a digital voltmeter and measure the total pack voltage and then each individual battery voltage. 1 weak battery can cause your problem of short run time.
A fully charged cart should be 38.2v or more.
Post up your results and we can give you some ideas.
Here is a State of Charge chart to compare your readings:
Pat912
Thank you for the speedy reply! I'll have to slide on down to Lowes and pick up a voltmeter. It may be a few days before i can so PLEAE keep an eye on my post. I will update ASAP
-Pat
