DougSochan
I have gotten some amazing answers about my 2006 EZGO TXT PDS golf cart…and Thank You…This an issue that is perplexing me…could be motor burnt out, controller too hot, or whatever else I have not dove into. I fixed the cart to prime level because of your answers. Last week at camp not one issue 10 miles of driving or more, then got home still had charge used then plugged it got it back up to 38.2 volts sent it on to camp. I couldn’t go to much work to do. When it got home 1/2 of battery meter left (have simple green to red squares) so I took it to neighbors for work (design and build playsets) and drove back. It sat in the heat for 5-6 hours. While off no radio or other accessories (now on seperate 12v with kill switch) and kids took it out and it was not moving at all…towed it back to workshop, check pack volts…33.6v…hit the tow / run switch off while check the pack turned back to run and it moved out but could see it slowing so immediately back to shop…can the days heat affect controller to go into thermal protection, I asked about amount of kids on it at camp…I know TXT is about 500 lbs of capacity, so battery pack, lift, tires, et all…hoping not motor burnout…I am going to look for motor reset… if need be … and suggested… but any sound advice from you folks???
