EZGO Golf Cart Reed Switch Testing and Bypass
Check for battery pack voltage at the small white wire coming out of the back of the charger receptacle. If there's no voltage reading the reed switch is blown. You can unplug the connector on the red/white wire and run a jumper from the red wire on the reed switch connector to the main positive terminal on the battery pack to by pass the reed switch.
