Drive belts size?
Dre0256
Can you get drive belts in different sizes for like custom applications? If so where can I look? Thanks
Dre0256
From my last post where you helped me out alot, I was able to correctly fit the engine. However since the starter is on the back of that predator motor the engine sits about and inch further forward, which makes the belt to tight and why I couldn't shift with out shutting the motor off.
Your better off to do the measuring and see what number ya come up with, what drive clutch is on there?
Well that is a stock RXV drive clutch, belt width for that clutch is 1-3/6" if i remember right. 15/16 is way narrow
