Drag Racing Golf Carts In California
MrWicked
the new wheels for the sand drags should be here tomorrow then we will take them to get powder coated semi gloss black :thumbsup:
MrWicked
you guys should just drive out and race with me....
do you have 4 pc925s???? it looks like our west coast supplier is out of batterys
MrWicked
the 15:1 gears showed up and some paddles and rims also came in today.... just waiting for 4 more batteries
GarageBuilt
Well-Known Member
Randy how do you plan on keeping the front end down in the sand...? You going to ues the same wheelie bars you have now...
MrWicked
our plan is to use the same wheelie bar but add a mount for the go-kart wheels and slicks...
but we might have to make a whole need set of bars.... running out of time...
MrWicked
well we got the tail light problem solved just a little LED bike tail light...we already had tabs on the cage for the number plate... that we moved to the wheelie bars
and i think i have figured out what we are doing for the wheelie bars...
we will make a axle that bolts on the where the little wheels were bolted on and run these spindle mount wheel with rain tires on them :thumbsup:
MrWicked
GBR you keep talking about to have ran a cart in dirt and sand drags.... how long was the track??? what size tires where you running???? and if sand what kind of paddles and how many paddles????
thanks for all the info
MrWicked
got the sand drag bars tack welded.. this will have to work for now.. when i have more time ill make something liter and wicked looking
MrWicked
ok 15;1 gears are in and the diff is sitting in the cart... the new bigger battery box is in with 10 pc925's... 4 new batts showed up today...
GarageBuilt
Well-Known Member
Stupid me!!!! :rotflmao: I thought you would use at least 2/0 wire. Are maybe even buss bars...The battery terminals look real close in the pic... They could arc yes... :dazed:
MrWicked
well the batteriess were just sitting in there for now... we will turn them around and have all the batts facing all the same way....
very disappointed about the rear end... very very very load :wallbash:
most have done something wrong so have to open it back up and see what i did wrong...
GarageBuilt
Well-Known Member
Check all the bearings... Plus the wheel bearings... More than likely the gears just have to seat them self’s... Looks like you already have it taken care of it...I am just slow to post...
