Hmm, looks like we've got another build about to happen. Cool!
Day 13 (8-9-2019) of the Lithium Ion 2002 Club Car DS
DAY SEVEN OF THE FIRST FULL CHARGE
PERFORMANCE AND RUN-TIME RECORDING
The Li Ion batteries were fully charged on 8-2-2019, with a final voltage of 57.0 volts. Data is being recorded each day to see how the batteries perform until they are discharged to about 48.3 volts, which is the sensible lower limit for good battery life.
Data for Day 1 (Aug 3)
Start today at 57.0 volts (full charge), ended today at 55.5 volts, 3.14 miles traveled today.
7.43 Amp Hours used today. 411 watt hours used today. 131 watt hrs per mile.
Avg speed 6.81 mph, max speed 16.3 mph, max amps 126, run time today 28 minutes.
Data for Day 2 (Aug 4)
Start today at 55.5 volts, ended today at 55.3 volts, 1.16 miles traveled today, 4.30 miles total on this charge.
10.4 Amp Hours used on this charge. 573 watt hours used on this charge. 133 watt hrs per mile.
Total run time on this charge 38 minutes.
Data for Day 3 (Aug 5)
Start today at 55.3 volts, ended today at 55.0 volts, 1.21 miles traveled today, 5.51 miles total on this charge.
13.7 Amp Hours used on this charge. 755 watt hours used on this charge. 136 watt hrs per mile.
Total run time on this charge 51 minutes.
Data for Day 4 (Aug 6)
Start today at 55.0 volts, ended today at 54.5 volts, 2.02 miles traveled today, 7.53 miles total on this charge.
18.3 Amp Hours used on this charge. 999 watt hours used on this charge. 134 watt hrs per mile.
Total run time on this charge 64 minutes. Max speed today 18.9mph.
Data for Day 5 (Aug 7)
Start today at 54.5 volts, ended today at 53.0 volts, 3.52 miles traveled today, 11.05 miles total on this charge.
26.8 Amp Hours used on this charge. 1,448 watt hours used on this charge. 131 watt hrs per mile.
Total run time on this charge 1 hour and 28 minutes. Max speed today 26.7 mph (going down hill way too fast).
Data for Day 6 (Aug 8)
Start today at 53.0 volts, ended today at 52.1 volts, 1.95 miles traveled today, 13.00 miles total on this charge.
32.22 Amp Hours used on this charge. 1,731 watt hours used on this charge. 134 watt hrs per mile.
Total run time on this charge 1 hour and 48 minutes.
Data for Day 7 (Aug 9) FINAL DAY OF TEST
Start today at 52.1 volts, ended today at 46.3 volts, 3.27 miles traveled today, 16.27 miles total on this charge.
40.38 Amp Hours used on this charge. 2,134 watt hours used on this charge. 131 watt hrs per mile.
Total run time on this charge 2 hour and 21 minutes.
I missed the minimum voltage target of 48.3 volts, and instead went 2 volts lower to 46.3 volts. I will analyze the data tomorrow when I am fresher and try and present some thingp useful data. I think the voltage fell off a cliff at the end of the test
Still more to come!
