DAY 6 - MORE MUMBO JUMBO
I did about a mile and a quarter in the cart this morning but was thinking how the charger had cut off a little prematurely yesterday at 55.6 volts. I knew it should have gone higher. So I was talking to my bike buddy and he said I needed to finish the charging to really get the power and distance testing done correctly. Ok, sometimes you just need someone else to tell you. So I fiddled with the cut-off voltage in the charger and was able to continue charging the batteries to a full 57.1 volts. (Full enough for me, anyway.) After resting for an hour they stabilized at 57.0 volts. Significantly higher than the 55.6 volts from yesterday. Also, the charging added back in the amp hours I had used up this morning and then added an ADDITIONAL 9.8 amp hours. That means the cart is now fully charged with about 45.9 amp hours at 57 volts. (Technically, I'd need to use the average discharge voltage, but )
Ready to go for tomorrow.
