Directionals Not Working
ezgodave
My directionals aren't working on my EZGO 36 volt golf cart. I can hear the clicking sound at the flasher but the lights don't flash. Don't know if it's related but the voltage meter isn't registering either.
Will appreciate any input and diagnostics!
If the flasher is clicking you've got power going to it. I'd start with checking the bulbs and any connections in the turn signal wiring. If all the connections are good you'll need to use a test light to or volt meter to see where the problem is. Welcome to the forum. :hattip:
I would check to see if there is power on both sides of the flasher when the lever is on.
