I have read on here that you need to use welder cable when changing battery cables and not the automotive cable. I have both in my shop and can not see much diff between the two. The only thing that is different is that the welder cable has an extra layer of insulation. Both have the small wound copper wires. Copper wire is copper wire, correct? What is the difference between the two and does it matter if you use the automotive cable?
