I can charge my battery up and run my gas club car for just a while before the battery is dead and if i charge it and leave it sitting the battery will go dead.Any ideas on what my do this.
it sounds like it could be a charging and/or battery problem, did you check the voltage with the engine running? i would start with charging the battery with the positive cable off and see if the battery holds a charge. if so your problem may be your voltage regulator.
I left the cables off and battery held a charge and i hook up cables and tested with volt meter while running and seeem to be charging.Anymore ideas to try.
