Golf Cart Wizard
Starting off with a 2021 Club Car Tempo, building it with a Navitas 600A / 4kW AC conversion and Eco Battery 105 AH lithium battery. To start I stripped down the golf cart and pressure washed everything clean. If you want a guide on how to take it apart go here: Club Car Tempo Teardown Guide
Now you don't have to strip the golf cart down to do this, you can leave the rear body and underbody on but since we're building it it's easier just to have access.
So to start you remove the T40 mounting plate screw
Now unscrew the 3 #2 philips screws holding in the charge port. Rotate and pull into the battery compartment. Then unplug the MCOR and clip the tie wrap under the passenger side cup holder and pull the harness into the battery compartment.
Now unplug the speed sensor and remove the cables from the motor (1/2" and 7/16" nuts), pull the mounting plate forward and up, and feed through the motor cables:
Now you can set the whole assembly onto your workbench for easy access to everything. More to come later
