My 2013 Cushman 1200 Hauler gas aka EZGO MPT 1200 is draining the battery . I tested for amp draw and its high from the negative to the relay with the key off. I can hear the relay click when the negative is reconnected. I am assuming it is staying energized all the time even with the key in the off position.
All other circuits are fine.
My question . Could it be the key switch. Or possible the solenoid. Any advice on where to start or how the check the key switch would be appreciated. As a temporary measure I have installed a battery shut off on the negative side of the battery
Thanks
Thanks
