Curtis State of Charge Indicator
wildduk
I have a 48 volt cart. After I charge the batteries, the Curtis state of charge indicator stays in the same spot. If I remove the leads of the charge light and let it reset, it then will show a full charge, and go down like it should When using the cart. Then when I recharge again, it stays in the same spot....
Voltage across the battery bank is 51v after a full charge....
What should I look at next?
thx
Zman
Most of those meters reset at 56.1 volts. You need to check the voltage when charger is close to shutting off. If that is okay then i would suspect meter is bad,
