DAVE WALKER
Good afternoon everyone,
Having trouble with our Cruise Car, this issue started when it was driven in a heavy heavy down pour. When you turn the key on the starter try's to start the engine without pressing the accelerator. If you step on the accelerator it will finish starting the engine and you can drive it for a while till the battery goes dead in it. The generator charges at 15v when the throttle is pressed to full and maintains 13.7 volts when the throttle is about 1/2. even after the engine is warm it still wont stop trying to start the engine. This cart never tried to start the engine before by just turning on the key. I did check the voltage regulator and it seems ok. The serial number is 10622. I believe this to be a 2010 cart gas powered. Any ideas?
