I hadn't heard of these before but I have heard the manufacturer Panduit. They are or were a major supplier of the large zip ties used on flex duct in HVAC. As a matter of fact most HVAC guys I know referred to those big zip ties as panduits. Panduit apparently branded themselves well like Kleenex, Vise grip or Channellock. Nobody says hand me the slip joint pliers. Some of these guys fabbing ductwork would play a joke on people by sneaking under your truck and putting a "Panduit" cinched down on your drive shaft. It wouldn't do any damage but it would make a hell of a noise until you cut it off.
Thanks for the tip on another way to a make splice with good structure, continuity and moisture resistance. What type of spade connectors do you use when the need arises?
