where do the crankshaft shims go, between the dual bearings or one on each side of the crank?
J jackson2 New Member Feb 25, 2012 #1 where do the crankshaft shims go, between the dual bearings or one on each side of the crank?
Nubs Cartaholic - V.I.P. Mar 10, 2012 #3 as long as it spins free you should be good, is it runnin' yet?
P Pinhead New Member Mar 18, 2012 #4 Im new here and have the same problem end play on the end of the crank on the end of the clutch.Where did you get your bearings?
