ACEGOLFCARTGUY
Have another project I'm excited to work on. This lucky cart was an electric 2002 Club Car that I am converting to gas using an EZGO rear end and a new Honda clone engine. (these are in random order)
I finished the engine cradle and mounted the engine.
I designed the engine cradle to mount on top of the axle so that it has more ground clearance and a better chance of not dragging over rocks.
The tires are 25 x 12.50 and the Z bracket lifts 10" up and 5" out. I ordered wheel spacers to go all around, but will probably only use them in the front so it matches the width of the rear. I've installed a Z lift before but this is the first one I fabricated. I built it out of 2 x 1 x .120 wall tubing and added a 2" square tube vertically for extra support.
Engine cradle almost finished
Engine crade with cross members welded in.
Cool weld-on heim joint I found at tractor supply
Building the engine cradle from 1 1/4 11ga mild steel tubing and 2 x 1 tubing
13hp clone engine with the 2 year warranty. These things really are peppy!
More to come!
More to come!
