Elmerfud67
Yes sir. I will do it.
And let you know
Thank you for your time. I appreciate the help.
And let you know
Just confirming, are these voltages, battery and controller input voltages, measured under load? If not, they should be.I charged the cart up fully 53.7 volts.
53.7 @ Positive side of Solenoid and 52.2 on the outgoing side of Solenoid with no diode installed.
52.2 @ A1 on controller. Press pedal it drops 2 volts and returns to 53. 2 and holds.
Go to motor and basically same numbers.
HOWEVER, when checking A2 on motor it goes from 52.2 down to 20 volts and jumps around to 36 back to 28 very sporadic.
I am changing the cable now and going to test it again
