clutch ???????
kawman14733
how do ya get the rear belt pully off bolts off, inner moves, outer sheav dosent is it pressed on shaft. when i turn one sheave one way and the otherside the other it moves but dosent snap back i think the spring is broke unless there is two springs in the thing . help it runs fine just wanted to clean clutch real good,////////////////duh it might help if i told ya what it is 1983 g1 2 smoker
Yes outer sheave is on a tapered keyed shaft, Best bet is to make or buy a puller. There's 2 threaded holes about 1 1/4 each side of main nut. DO NOT USE A WHEEL PULLER you will regret it.
kawman14733
thanx for the reply tom . any chance you got a pic ov tool needed or place to buy one . is it a bolt type puller like they use on snomobiles clutches
