Welcome RPM
the spring for the drive clutch is easy, just pull the outter cover and switch them out.
the spring for the driven is a bit harder, you need to remove it from the axle and remove the snap ring that holds the ramp cup on but you want to hold the cup down when removing it because there is some spring pressure on the cup.
