Clutch Replacement for 1983 Columbia Par Car DX4?
jhaf11
I had the bolt that holds the clutch to the engine back out and fall on the ground along with the outer part of the clutch. Disassembled the clutch and put the weights back in the holes I thought were right and reassembled. It seems to work, but there is a noise, not sure if it is drive or driven clutch. It also seems to struggle on hills now. Was going to replace drive clutch, but having troubles finding one. The more I read, sounds like the driven clutch is the one that fails. Any advice out there?
