You can test a solenoid with a volt meter. When the solenoid is open no current should pass through the large posts. When the solenoid is closed or activated the voltage will pass through the large posts.
Check all the solenoids. More than likely the furthest one to the right (passenger side) is bad but check them all. And double check your battery wiring.
