Club Car Stopping When Throttle Pedal Is Pushed To Floor
ezgoesit
Having troubles with a Club Car. The cart is stopping when the throttle pedal is pushed to the floor. When i push the gas pedal lightly it will go but when the pedal is pushed all the way down it just stops. Anyone have some suggestions on what the problem may be its a 48 volt club car carry all 2 2009
shadowman
i would start by checking batteries and cables...............teat and load test each battery you only need one to be iffy or fail under load to cause this.......................................
dansgolfcars
Does the cart go to a certain speed then shut down and then when you let off the accelerator and push again it will go? Check the speed sensor. It's on the end of the end of the motor and has two wires leaving it.
