I have a 2001 48 volt Club car, and stupidly forgot to disconnect the battery and put it on "Tow" when I was cleaning the two main side-by-side terminals on the electric motor. I accidentally connected them, causing a momentary spark. The car was in-op after that. I checked the solenoid and found the diode burned and smoking. I replaced the solenoid, and now the cart moves but only goes into reverse with the rocker switch on both F and R. I am sure I hooked up the new solenoid correctly.
Did I damage the controller as well, or is there yet another component that became damaged that might be causing this problem? Thanks for any guidance!
