I have a 1999 DS which has had a delay in starting for awhile. I push the pedal down, the solenoid clicks, and nothing happens for about 5 seconds before the cart fires up. Sometimes it fires up right away, so this is an intermittent problem. I thought maybe the starter belt was loose, so I tightened that up. Still the same problem. I started watching the starter when I push on the pedal, and the pulley will turn just a little bit, stop for a few seconds, and then start. I was told the brushes were bad, so I took the starter out and brought it in to get looked at. The brushes turned out to be fine, and the starter bench tested fine. Any thoughts on what this could be?
It almost seems like there isn't enough power to the starter at the initial demand to turn the pulley. Possibility of a weak battery?
Any help is appreciated. Thanks
