Club Car Precedent DOA
Jake608
New member with a problem someone may be able to help with a Club Car Precedent that's DOA!
I have checked and my assertion is a bad controller.
Cart was running fine with no issues. Now turn the key on and NOTHING! Batteries fully charged 50v. Switch to reverse, no alarm. Press accelerator no click, zero and no movement.
Checked Solenoid ohm meter and is good.
Checked (-) to key and zero volts. Check (+) to switch 50v. Problem is in both positions it test 50v on and off.
F/R switch also has 50v at all positions L-M-R no matter what position 50v.
Tested Run/Tow switch and 50v at both terminals. Tested switch ohm meter with no load and it functions perfectly.
Solenoid red from battery pack 50v yellow 50v in off or tow position.
Even the alarm buzzer has 50v on one side but does not buzz.
I’m new my Club Car and am working to get it completed. Lift kit, rim and tires, rear seat, etc. Now this has me frustrated!
ANY HELP IS APPRECIATED IF YOU. KNOW WHERE TO LOOK OR HAVE HAD SIMILAR ISSUES, THANKS!
Jake608
Yes but with no help here! The problem was solved by me downloading the wiring schematic on line, not the wiring diagram. There I found a 10amp diode in the hot feed to the Run/Tow switch that energizers the entire system. There was +/- voltage on both sides of the inline fuse but nothing to the switch immediately after. Jumped the line directly to the Run/Tow switch and BAMM a fully functioning system!
