semurray00
I have a 48 volt Club Car with a voltage reducer. I have a headlight and led taillights. I added a turn signal kit. The flashers work, except when the lights are on. The front turn signal lights will come on when activated, but will not blink. The rear turn signals will not work at all. My original light kit has an extra black and red wire on each of the front headlights. I ran that black wire to the bolt on the back of the amber lights. I connected the appropiate turn sighal wire to the black wire coming from the amber light. I still have not used the extra red wire on the front headlights. When I tried to incorporate these red wires, i ended up with flashing headlights and turnsignals no matter which way i turned the switch. Unfortunately there was very little instructions for the turn signal kit and I cannot find my light kit information. I assume that i've screwed up the wiring sequence. Any help or suggestions would be greatly appreciated. Also, all other 12 volt applications are working fine, as are the headlights and tail lights. I do have a heavy duty flasher as part of the kit. The only wire that i didn't use from the wiring harness is the 8th wire for a brake, since i do not have a brake switch.
Thanks
Thanks
