Club Car KF82 341cc Engine Compression Specifications
CCRider
Hey everybody, just need some information and input on what the factory specification compression rating is for the Club Car KF82 341cc engine? I have been told that the stock compression ratio is 6.0:1 and that the factory compression spec is 100 psi. but would like to know for sure. I did a compression check and it was 112 psi.
If what I have been told is true, can the stock compression be higher than factory specs!? Or is it an indicator that the motor may have been rebuilt resulting in the higher compression??
Thanks
Greetings, anything over 100 is great. When you do the compression test make sure the throttle pedal is to the metal or else you'll get a false reading.
