what is the best way to seat the studs in a CC front hub? Can any type of lube be put on the stud grooves? thought about putting a deep well socket under the hub and just knocking it down, but it marks the hub and one bad lick it might bend or worse crack. should they be flush on the back? Also need advise on packing bearings. swapping out the jakes 6" lift for 7.5" allsport that should be in soon. decided to go ahead and replace the complete hub assembly.
