So i just picked up a Club Car DS with a 16hp Honda clone engine conversion, comet 500 series clutch and have a question. The way its set up now, it cannot change gears without completely shutting down the cart, and motor is always running even when not on the gas.
Can this setup be adjusted to shift gears while the engine is running, or be modified to run like a stock setup by only running when gas is pushed?
Any help is appreciated, Thank you.
