Club Car Golf Cart Bad Drive Clutch?
chachi44089
I think I may have a bad worn out drive clutch on my Club Car golf cart. Here is whats going on. I have adjusted everything I can on my cart to get a little more speed out of it. It is running great and just under the rev limiter, but the fastest I can go is 11mph and 12 down a slightly graded road and I hit the limiter on that. I put the cart in service mode and with the pedal to the floor I noticed the top of the drive belt is about 3/4 of an inch from the top of the drive pulley. Could this be my problem? Is it an easy "cheap" fix? How hard is it to pull the clutch? Do I need to pull it to check or fix it? I would love to go 13-14mph.. Any help appreciated.
I forgot to add that I have a 93 Club Car gas with fe290..
shadowman
Have you tried adjusting the low speed cable coming out of the black box? Whatever you do if you start bouncing off the limitor put a tach on it.
