Club Car Forward Switch Loses Contact
jbc118
Hello, I'm new to the forum and I have a quick question..
I just installed a 6" spindle lift on my 2006 Club Car DS gas golf cart and ironically my forward shift lever contact switch keeps popping out and loses contact.
I've tried to adjust the length of the cable. It seems that maybe that yellow lobed wheel that's used for maintenance mode may be worn?
I've tried to bend the switch tab to give it more connection but that's not working.
So typically it's fine but if I take the cart across the yard and it bumps a bit the switch moves and I have to manually jam it back into forward.
Any thought's would be appreciated..
thanks..
It sounds like it's not going in to forward gear all the way. Are you sure you have the cable adjusted correctly? Did you ever have this problem before you installed the lift kit? Welcome to the forum. :hattip:
